Engine mount support bracket
140,000 MILES • 4.9L • 6 CYL • 4WD • MANUAL
NATHANK0012
I can't find the engine mount support brackets anywhere. do i need to change the perches to the newer style? is that even possible without major changes?
Sep 16, 2019 at 9:38 PM
Good morning,
What happen to the old perches?
Can you upload a picture of the mounts?
Sep 16, 2019 at 10:00 PM
NATHANK0012
the perches are there but the upper support brackets that bolt to the block where gone when the truck arrived, Apparently you can't buy them.
Sep 16, 2019 at 11:36 PM
That is correct. They were discontinued years ago.
I would suggest going to a junkyard and taking them off an engine in the junkyard.
Sep 16, 2019 at 11:42 PM
