Engine mount replacement
18,000 MILES • 1.6L • 2WD • AUTOMATIC
JRMAFIA
I need to replace the engine mount and support mount on my car (VA Polo), but the part is not available in my country.
The car that i am driving now is a right hand drive.
The same car is available in India (VW Vento), but the car is a left hand drive.
Will the engine mount of a left hand drive fit into a right hand drive vehicle, or does it even matter?
Hope my question is understood. :)
Nov 10, 2019 at 7:31 PM
  • 110,248 POSTS
Hi:
I would believe they are the same regardless of left or right hand drive. Are you able to upload pictures of the two to compare?
Although the driver position changes, the engine and transmission will not change orientation, so it should be fine. However, I do recommend trying to see if you can upload pics just to confirm.
Let me know if this helps.
Nov 11, 2019 at 11:17 AM
