Engine missing especially on incline Service Stabilitrak light on?
119,843 MILES • 4 CYL • 2WD • AUTOMATIC
TANGY CARPENTER
I have had the spark plugs changed and the coils, it helped for a couple of months. Now it is starting to miss again. The check engine light flashes and a message Service Stabilitrak comes on. If I turn off the traction control it seems to miss less. I have had the spark plugs replaced and the coils.
Dec 13, 2025 at 3:41 AM
  • 55,746 POSTS
It sounds like they may have cracked one of the spark plugs or you have a defective ignition coil, but to be sure we need to run the codes which should tell us which cylinder is having the issue. The Service Stabilitrak can come on when the engine is misfiring so lets handle that problem first. Here is a guide to help.
Please go over this guide as well
Please go over these guides and get back to us. Ken
Dec 15, 2025 at 4:22 AM
