When I accelerate going up inclines engine has a miss sometimes on level ground it miles it is bees around.
Nov 24, 2016 at 1:15 AM
WRENCHTECH
✓Experienced Mechanic
Probably a bad coil or two. You will have to determine which ones using a scan tool. Unless they were just recently done, you should change all the plugs at the same time.
