Engine misfires
150,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ACTIONAUTOREPAIR
  • 19 POSTS
While accelerating it misses.
Mar 28, 2018 at 2:11 AM
Good morning.
The first thing I would do is basics, such as spark plugs. that is the most common reason for miss fire under load.
How old are your spark plugs?
Are there any codes?
Mar 28, 2018 at 3:03 AM
ACTIONAUTOREPAIR
  • 19 POSTS
Spark plugs new, also new brain but, scanner is not reading it.
Apr 3, 2018 at 6:03 AM
Is the scanner reading any info??
Have you checked fuel pressure?? low fuel pressure will cause miss fires.
Apr 3, 2018 at 6:06 AM
ACTIONAUTOREPAIR
  • 19 POSTS
Also several other parts have been replaced.
Except the spider fuel injectors not replaced.
Last time it was running I could smell fuel.
Apr 3, 2018 at 6:09 AM
thats common when the pressure regulator is leaking into the intake. take the upper intake off and inspect. bet you find puddles of fuel.
Apr 3, 2018 at 6:11 AM
ACTIONAUTOREPAIR
  • 19 POSTS
My hubby isn't here to say but I believe the pressure regulator has been replaced if not then the fuel pressure was checked let me ask him.
Apr 3, 2018 at 6:29 AM
pressure regulator is part of the spider. it is rare just to replace the regulator.
Apr 3, 2018 at 6:48 AM
ACTIONAUTOREPAIR
  • 19 POSTS
He said regulator was replaced
About the spider I thought it had but not positive
Apr 3, 2018 at 7:08 AM
Thats where I would start.
Apr 3, 2018 at 7:17 AM
