HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Suburban
Engine
Symptoms
Misfire
SPONSORED LINKS
Engine misfires
ACTIONAUTOREPAIR
MEMBER
1999 CHEVROLET SUBURBAN
5.7L
V8
4WD
AUTOMATIC
150,000 MILES
While accelerating it misses.
Wednesday, March 28th, 2018 AT 9:11 AM
MECHANIC
Good morning.
The first thing I would do is basics, such as spark plugs. That is the most common reason for miss fire under load.
How old are your spark plugs?
Are there any codes?
SPONSORED LINKS
Wednesday, March 28th, 2018 AT 10:03 AM
ACTIONAUTOREPAIR
MEMBER
Spark plugs new, also new brain but, scanner is not reading it.
Tuesday, April 3rd, 2018 AT 1:03 PM
MECHANIC
Is the scanner reading any info?
Have you checked fuel pressure? Low fuel pressure will cause miss fires.
Tuesday, April 3rd, 2018 AT 1:06 PM
ACTIONAUTOREPAIR
MEMBER
Also several other parts have been replaced.
Except the spider fuel injectors not replaced.
Last time it was running I could smell fuel.
Tuesday, April 3rd, 2018 AT 1:09 PM
MECHANIC
Thats common when the pressure regulator is leaking into the intake. Take the upper intake off and inspect. Bet you find puddles of fuel.
SPONSORED LINKS
Tuesday, April 3rd, 2018 AT 1:11 PM
ACTIONAUTOREPAIR
MEMBER
My hubby isn't here to say but I believe the pressure regulator has been replaced if not then the fuel pressure was checked let me ask him.
Tuesday, April 3rd, 2018 AT 1:29 PM
MECHANIC
Pressure regulator is part of the spider. It is rare just to replace the regulator.
Tuesday, April 3rd, 2018 AT 1:48 PM
ACTIONAUTOREPAIR
MEMBER
He said regulator was replaced
About the spider I thought it had but not positive
Tuesday, April 3rd, 2018 AT 2:08 PM
MECHANIC
Thats where I would start.
Tuesday, April 3rd, 2018 AT 2:17 PM
Please
login
or
register
to post a reply.
Related Engine Misfire Content
1999 Chevy Suburban Occasional Engine Miss
Have An Occasional Engine Miss At Highway Speeds. Frequency Seems To Increase As Speed/rpms Increase
Asked by
Suburbanguy11
1 ANSWER
1999
CHEVROLET SUBURBAN
VIDEO
Intermittent Misfire
Instructional repair video
GUIDE
Misfire Random Code P0300
The world of automotive diagnostics can be complex, with numerous codes and potential issues to keep track of. One of the more common engine diagnostic codes is P0300, which...
1999 Chevy Suburban P0300 Random Misfire
Tech Just Did A Lower Intake (coolant Leak) Now I Get A P0300 Check For Misfires #2 And #6 Are Missing Firing (no Codes) They Are Exact...
Asked by
Turbovtx8
1 ANSWER
1999
CHEVROLET SUBURBAN
1999 Chevy Suburban Missfire Cylinder #4 At Idle
I Have A Miss On Cylinder#4 At Idle Goes Away Above 1000rpm, No Vacuum Leaks Found, New Plug, Wire, Cap, Rotor. Checked Flow At Spider...
Asked by
JIM FITZMAURICE
1 ANSWER
1999
CHEVROLET SUBURBAN
1999 Chevy Suburban #2 Cylinder Misfire
Engine Problem 1999 Chevy Suburban V8 Two Wheel Drive 121000 Miles The Service Engine Soon Light Illuminated And I Had The Fault...
Asked by
wmm83pack
1 ANSWER
1999
CHEVROLET SUBURBAN
1999 Chevy Suburban Misfiring
My 1999 Suburban With A 5.7 Has A Intermittent Miss. It Will Do This While Accelerating Or When I Am At A Steady Speed. I Was Told It Needed...
Asked by
Archabald
1999
CHEVROLET SUBURBAN
VIEW MORE
SPONSORED LINKS
How to Repair an Engine Cylinder Misfire
Online car repair manuals
