Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Liberty
Engine
Symptoms
Misfire
Engine misfire
2002 JEEP LIBERTY
215,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
BENJAMIN E. BIGLEY
MEMBER
1 POST
I have replaced the coil pack, cam sensor, crank sensor, heads, injectors and the engine still has a mis.
Aug 26, 2017 at 2:09 PM
Experienced Mechanic
Here is a good way to see which cylinder is acting up.
https://youtu.be/QTE8k06MzwQ
Also I would do a compression test to see if any are low. If you don't have a gauge you can rent one form the auto parts store for free. When you had the plugs out do any look different from the rest color wise?
and
Let me know what happens.
Cheers, Ken
Aug 28, 2017 at 10:30 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
