Engine misfire
215,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
BENJAMIN E. BIGLEY
I have replaced the coil pack, cam sensor, crank sensor, heads, injectors and the engine still has a mis.
Aug 26, 2017 at 2:09 PM
  • 55,766 POSTS
Here is a good way to see which cylinder is acting up.
https://youtu.be/QTE8k06MzwQ
Also I would do a compression test to see if any are low. If you don't have a gauge you can rent one form the auto parts store for free. When you had the plugs out do any look different from the rest color wise?
and
Let me know what happens.
Cheers, Ken
Aug 28, 2017 at 10:30 AM
