Engine miss worse under load
80,000 MILES • 3.3L • 6 CYL • 4WD • AUTOMATIC
KEITH297
Engine miss not real bad on flat, on hill or passing gear real bad it sounds like popping though intake. Did have code for nox sensor with out light on. I have changed plugs, cap and button, nox sensor, fuel filter, and filled with 93 octane. also, checked compression test. I am now thinking distributor or timing belt.
Nov 29, 2017 at 9:55 PM
  • 110,251 POSTS
If the compression is good, it does not sound like a timing issue or at least anything with base timing (belt). Let me know what the compression readings were. Here is a link to help with finding compression. If the only code you got was for a nox sensor, are you sure it is an engine miss and not an issue with the transmission?
Do me a favor, and this is old school, so do not laugh. When it is dark outside, start the engine and open the hood. Mist water on all ignition components to see if there is something sparking.
Nov 30, 2017 at 10:27 AM
KEITH297
Checked for any sparking.seen nothing. On the compression test all had 200, except number six. tried three times, it was at 160, but sounded like tester would not seal. cleaned o-ring,checked hole all looked good. Still had a popping noise from somewhere. Tried in another hole again an tester fine. Number six is the plug i took out when i change them i dropped and did not find to see what it looked like. could this be a head gasket leaking under pressure? Also, when starts the popping noise on a pull it looks like something coming out exhaust maybe raw gas. thank you for your help.
Nov 30, 2017 at 7:28 PM
  • 55,797 POSTS
To me this sounds like you have camshaft that is going flat on one of the exhaust lobes. My guess would be number six. I would remove the valve cover and take a look at the camshaft.
Here is a guide to help you see what you are in for when removing the valve cover:
https://www.2carpros.com/articles/replace-valve-cover-gasket
Also, this guide can help as well it shows what a flat cam looks like.
Please let us know what you find.
Cheers, Ken
Dec 3, 2017 at 5:27 AM
KEITH297
Thank you for your help . we tryed a new distributor an that took care of the problem.
Dec 4, 2017 at 4:58 AM
  • 55,797 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Dec 4, 2017 at 5:17 AM
