Engine miss, check engine light turns on after engine idled for about ten minutes
90,000 MILES
CWILLIAMS55
Replaced spark plugs, core packs and mas air flow sensor. same problem. not seeing any codes.
service engine soon light comes on after car has idled for about ten minutes. light goes off when driving.
May 13, 2013 at 12:18 AM
CADIEMAN
  • 3,544 POSTS
if the service soon light is coming on it has to be setting a code.have you performed a compression test on the engine?
May 13, 2013 at 2:58 AM
CWILLIAMS55
no compression test has been done.
May 19, 2013 at 10:55 AM
CADIEMAN
  • 3,544 POSTS
if the light is coming on then it has to be setting a history code. I can't help you without this code.
May 19, 2013 at 12:22 PM
Good evening,
I would start with a compression test. Make sure all the cylinders are within 20 pounds of each other.
The code would help but you need to do the basic tests first.
You also could have injectors that have dirt in them. Additives have no effect on cleaning. you need to have them done professionally. that is when they disable the fuel pump and run the engine on pure injector cleaner.
Apr 24, 2020 at 10:07 AM
