Engine misfires when warm
91,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
CONORE
Hello, my car is misfiring when warm on cylinder two. I can drive for about ten to twenty minutes and it'll be fine. Once it's misfired, if I restart the car it will run properly for about one minute and then start to misfire again.
I have changed the spark plugs, spark plug leads and coil pack and nothing has changed and I also cleaned out the air filter. There appears to be some sort of grease when I take out the spark plugs after a couple of days so I think the engine may be running rich but this could be caused due to the misfiring.
Any idea of what to do/look for?
Thanks in advance.
Jun 18, 2019 at 1:38 PM
  • 55,694 POSTS
It sounds like you have the wrong weight oil in the engine causing the lifters to pump up or an injector that is starting to go bad. To confirm lets run the codes to see what is going on.
Fluid Types
Engine Oil
U.S.A. .................... Motorcraft SAE 5W-20 Premium Synthetic Blend Motor Oil
Canada .................... Motorcraft SAE 5W-20 Super Premium Motor Oil
Ford P/N .................... XO-5W20-QSP (U.S.A)
Ford P/N .................... CXO-5W20-LSP12 (Canada)
Ford Specification .................... WSS-M2C930-A with API Certification Mark
NOTE: Use of synthetic or synthetic blend motor oil is not mandatory. Engine oil need only meet the requirements of Ford specification WSS-M2C930-A and the API Certification mark.
Capacities
Engine Oil
With Filter .................... 4.25L (4.5 Qt)
Please let me know
Jun 20, 2019 at 6:56 AM
