Engine misfire/stall
178,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
THEDUDEINAJEEP
When driving after hitting a hard bump or rough road engine will misfire, resulting in the gas gauge falling to ‘E’ or it will stall completely. Could it be a loose spark wire, a fuel pump/filter issue?
Aug 24, 2019 at 7:29 AM
Do you know if there are any codes? This sounds like a loose ground or possible loose connection somewhere else. It is unlikely that it is a loose spark plug or fuel pump issue because if it "fixes" itself without you doing anything then more than likely it is a ground or connector.
Hopefully you have some codes and that will point us in a better direction. If you don't have a scan tool then most parts stores can pull the codes for you.
Let me know and we can go from there. Thanks
Aug 24, 2019 at 9:54 AM
