Engine Misfire #7?
56,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
JBCASTLES
  • 9 POSTS
engine light came on. received a misfire #7 message. replaced spark plugs, cables and engine coils. same message. replaced fuel injectors and now there is a loud tapping noise.
Jan 25, 2024 at 5:00 AM
  • 110,248 POSTS
Is it possible for you to record the noise and upload it for me to hear? Also, although there is a noise, does the misfire still exist? Was the P0307 misfire code the only one you found?
Does the noise seem to come from cylinder 7?
Take a look through this link and let me know if you feel anything mirrors what you hear:
https://www.2carpros.com/articles/engine-noises
Jan 25, 2024 at 11:58 AM
JBCASTLES
  • 9 POSTS
The PO307 has not reappeared. The car initially never made any knocking noise. Hard to tell exactly where the knocking is coming from. Which cylinder.
Jan 25, 2024 at 12:42 PM
  • 110,248 POSTS
If the code hasn't returned, then it appears the misfire has been resolved. Now for the noise. Is the knocking loudest at the top, side, or bottom of the engine? Is there a way you could record it and upload it for me to hear?
The idea this started with the injector replacement makes me question if the correct injector was provided to you. Also, were all spark plugs replaced, or on the cylinder 7 spark plug?
Jan 26, 2024 at 10:23 AM
JBCASTLES
  • 9 POSTS
I replaced all of the spark plugs, cables and ignition coils. I think you might be right regarding the injectors. I went with a less expensive injector (still new) but I wouldn't be surprised that by being cheap I screwed myself.
Jan 26, 2024 at 12:05 PM
JBCASTLES
  • 9 POSTS
The tapping did not happen until I replaced the injectors. Question, do you think OEM Bosch parts would be as good as genuine Bosch parts?
Jan 26, 2024 at 12:27 PM
  • 110,248 POSTS
Yep, I meant the injectors. LOL Bosch is the OEM part so I'm not sure I understand your question. Did you use an aftermarket part?
I attached the OEM part number below. Let me know if that is what was used.
See pic below.
Jan 27, 2024 at 10:26 AM
JBCASTLES
  • 9 POSTS
Jacob, when replacing the injectors, should I use a small amount of white grease on the o-rings of the injector?
Feb 5, 2024 at 2:17 AM
JBCASTLES
  • 9 POSTS
What are your thoughts on remanufactured parts vs new?
Feb 5, 2024 at 2:33 AM
  • 110,248 POSTS
As far as remanufactured parts, I base that on a few things. The first is the cost difference. Second, how difficult is it to remove and install a new part of the reman fails or is faulty? And finally, how much use the vehicle will get, and does the customer plan to keep it for an extended period?
Also, because this is a Mercedes, they can be very sensitive to differences. People often look for the least expensive part online. Many of the inexpensive online parts simply don't work. If you purchase one from a parts store, at least you have a better chance of getting a good one.
As far as the O-rings, yes, they should be lubricated before installation to prevent damage. Don't laugh, but I use Vaseline on injector O-rings. It works great.
Just FYI, anytime you are replacing O-rings, regardless of their purpose or application, you should lubricate them.
Feb 5, 2024 at 10:06 AM
JBCASTLES
  • 9 POSTS
The 2005 Mercedes CLK 500 uses 2 spark plugs per cylinder. The ignition coils have two spark plug connections, top and bottom. I currently have the top spark plug wire going to the front spark plug and the bottom spark plug wire going to the back plug for each cylinder. Is this correct?
Feb 13, 2024 at 11:11 PM
  • 110,248 POSTS
Although each coil has two spark plugs, both are for the same cylinder and fire at the same time. What you described does sound correct.
When you replace the spark plugs, it's a good idea to lubricate the spark plug boot with dielectric grease. This helps eliminate the possibility of moisture and helps maintain a good connection.
Feb 14, 2024 at 11:23 AM
