engine misfire
128,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
PRAMOD ELUVATHINGAL
my volvo s40 1.6 start misfire after the service (changed timing belt) after that its start misfire after two miles of run or when the temperature get half in the meter. I check with local volvo dealer they could't figure it out.
I replace EGR MAF AND COLANT SENSORS
It does't cure the problem, I noticed that fan is running more time than the usual even after engine is turned off.
Aug 8, 2016 at 8:43 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge. check for a vacuum leak and finally check compression. it may be an interference engine and bent a valve.
Aug 8, 2016 at 10:57 PM
PRAMOD ELUVATHINGAL
No codes throwing , fuel pressure is fine and compression is fine.
Aug 8, 2016 at 11:48 PM
PRAMOD ELUVATHINGAL
What's that mean valve bent?
Aug 8, 2016 at 11:51 PM
HMAC300
  • 48,601 POSTS
it means if timing belt was incorrectly installed or jumped the valve could have hit the piston and bent. but if compression is ok it is ok. have a local mechanic do a freeze frame and check sensors for being not or to much voltage as well as injectors and check for a vacuum leak.
Aug 9, 2016 at 2:24 AM
