Engine misfire
164,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
NORRDOGG
Developed a severe misfire while on a trip. Checked COP and injectors with multi-meter. All within spec. Found bad front coolant crossover and replaced intake manifold and thermostat. All spark plug bores in head are clean. Still have misfire. Compression test shows 150 - 160 psi. OBD11 scanner shows P0308 cylinder eight misfire. Can find nothing in particular wrong with cylinder eight.
Dec 27, 2018 at 11:38 AM
  • 110,248 POSTS
Try this. Switch the coil from cylinder eight with one from a different cylinder and see if the misfire changes cylinders.
Let me know what you find.
Dec 27, 2018 at 1:30 PM
