Engine misfire
SATURNTECH9
  • 30,869 POSTS
Was that pig tail thatvwss bad to the number one cylinder coil?
Saturday, October 15th, 2016 AT 8:05 PM
JOE1953
  • 806 POSTS
The connected end wasn't tight where it connect to the coil and it is tight now I think the pig is good how do I test the coil and spark plugs?
Saturday, October 15th, 2016 AT 9:32 PM
SATURNTECH9
  • 30,869 POSTS
So again was the connector loose on the number one cylinder?Also it's kinda hard to test the coil if it's a intermittent misfire. If it was a constant one we just see if the coil is sparking. So please tell me which cylinder the connector to the coil was loose on?Then we can make are next move.
Sunday, October 16th, 2016 AT 7:21 AM
JOE1953
  • 806 POSTS
The connector to the coil was loose on #2 coil I replace new spark plugs and when I disconnect the connector from the coil the connector broke the engine was starting before I did that but now it want start no firing no fuel pump coming on and when I disconnector from the coil the connector broke the engine was starting before but now it want start no firing no fuel pump coming I don't no what could have happen if the connector wires touch each other will that cause the engine not to fire and fuel pump not working? What all I need to check to fix the problem why it not firing and fuel pump not coming on? Please help.
Wednesday, October 19th, 2016 AT 9:23 AM
SATURNTECH9
  • 30,869 POSTS
So your sure you have no spark you checked for spark?Also you can't her the fuel pump turn on when the key is turned to the Run position?It really makes no sense unless you broke something or blew a fuse or something like that.
Wednesday, October 19th, 2016 AT 8:09 PM
JOE1953
  • 806 POSTS
Yes I check for spark there is no spark, the fuel pump is not coming on when turn the key to run, I check all the fuses under the hood thoses that I seen I didn't find any blown fues, is there another fuse box on this car and where it is locateded? I want to get this car back running. What could I have broke and what I need to check now what all the things that can cause the fuel pump not to work and no spark? Do this car have a ignition module on it? What control the fuel pump and the firing system?
Wednesday, October 19th, 2016 AT 8:41 PM
MIKEHAWKISARD.DS
  • 1994 TOYOTA CAMRY
  • 2.2L
  • 4 CYL
  • 200,000 MILES
Engine misses very badly in hot weather. Tachometer bounces erratically. Cool weather it runs good. Last mechanic threw parts at it hoping to get lucky and fix issue but no success. New fuel pump, swapped out computer, new distributor, plugs and wires etc, no change in performance. I think IAC or dirty injectors or mass air flow sensor. What do you think?
Sunday, August 6th, 2017 AT 8:24 PM (Merged)
