Engine MIL on
90,000 MILES • 1.8L • 4 CYL • TURBO • 2WD • AUTOMATIC
ASHUULU SIMEON
Outside temperature sensor already been replaced. Obd fault code P0073 still stored (ambient temperature sensor has a short circuit to battery). Could this be the wiring of connectors from the battery?
Jun 16, 2018 at 11:11 PM
  • 55,721 POSTS
Yes, it sounds like you have an open connection between the sensor and the PCM. Here is a guide that will help you check the connections just check the wire color the sensor so you know which ones to test.
Cheers, Ken
Jun 18, 2018 at 5:24 AM
