Engine management light on
2013 CHRYSLER GRAND VOYAGER
30,000 MILES • 2.8L • 6 CYL • AUTOMATIC
SHANMUGR
Engine light on no fault showing up and the vehicle is running fine.
What could it be?
Kind regards.
May 9, 2018 at 5:04 PM
Good morning.
Did you have the code checked by someone with a scan tool?
Usually there is a code set when the light is on. Otherwise it may indicate a module failure.
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
May 9, 2018 at 10:16 PM
