If I go over 2,500 RPMs engine goes into management mode, when I switch off engine and restart it clears.
Jul 1, 2025 at 6:52 PM
STEVE W.
✓Experienced Mechanic
There are many things that can cause this. The first step would be to use a scan tool to see what is stored in reference to it going into limp mode. You will want a higher-level tool than a basic code reader to see which modules are storing errors and data.
