Engine malfunction
101,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ERICAHN
Just replaced the vacuum pump. In order to replace it, I had to disconnect battery for a while. Job is done, but I see EPC, CEL warning light and panel says "service now"
EPC says engine malfunction.
OBDII scanner gives me codes :7E8 and 7E9.
Nov 7, 2017 at 1:39 PM
  • 31,937 POSTS
These are control module menu one for the engine and the other for the transmission.
Fault codes will be a P code or a B code or U code.
EPC is electronic pedal control you may just have to do a code clear. i would do this first.
Nov 7, 2017 at 5:45 PM
