Engine made low but roaring sound and now will hardly turn over, wont crank.
FORESTSFOREVER
  • 1992 ISUZU RODEO
  • 110,000 MILES
Vehichle sat idle for two months then had valve cover gaskets replaced. Engine ran well after, but with whooo sound from front of engine during acceleration. Drive belt replacement reduced the sound. Whooo sound stopped to be replaced by a sound like a pulley with bad ball bearings. Engine began faltering when slowing for stops while I was driving and went dead as I was returning home. There were no warning or check engine lights, oil pressure showed good and engine not overheated. I managed to crank it one time but it went dead within seconds. Though the battery is charged well the engine does not want to turn over, only very grudgingly for a few very slow turns, not fast enough for a start. Over the last year or so I added a pint of oil treatmeant twice. Have I caused my engine to seize or is there a (hopefully) better answer for my problem?
Monday, July 22nd, 2013 AT 6:14 AM
HMAC300
  • 48,601 POSTS
Have an assistant try to start the car and hit starter on body if car starts you need a starter
Monday, July 22nd, 2013 AT 7:27 AM
FORESTSFOREVER
  • 5 POSTS
Thanks for the message hmac300. The starter however doesen't seem to be the problem, it does respond to the turn of the key but will only turn very slowly like when the battery is almost dead. However, the battery charge is good and I used my other vehichle to jump-start just to make sure the battery was not the problem.
Monday, July 22nd, 2013 AT 6:22 PM
HMAC300
  • 48,601 POSTS
If you had to jump start it then check the battery for condition including load test. If it checks out ok then check cables for having same power as battery at starter if still screwed up remove starter and have it tested as well.
Tuesday, July 23rd, 2013 AT 5:35 AM
