Engine loses rpm's after hitting 2300 rpm's sometimes
135,000 MILES • 3.7L • 6 CYL • 4WD • MANUAL
GEORGE H. SMITH JR.
Changed all oxygen sensors and camshaft sensor engine light stays on. Sometimes at 2300 rpm's engine dies down to idle and the will go back up as long as i do not exceed 2300 rpm's have heard that should use OEM camshaft sensor. Any thoughts?
Dec 27, 2016 at 11:03 PM
  • 55,770 POSTS
Hey GEORGE,
This sounds like fuel pump problem, it must drop fuel pressure sometimes. Here is a guide to help you see if this is the problem
Please run this test and get back to us so we can continue helping you.
Best, Ken
Dec 31, 2016 at 6:18 AM
