Codes 654 and 452, Engine loping while driving?
235,000 MILES • 5.8L • 4WD • AUTOMATIC
GERRY SATTERWHITE
The engine lopes while driving, won't go over thirty-five MPH, that's when it starts shaking and bucking, runs fine at lower speeds (no bucking) just loping. most everything under hood (sensors) has been replaced or looked at. get 654 and 452 OBDI codes.
Nov 11, 2022 at 9:27 AM
  • 55,710 POSTS
Obd 1 codes are 2 digits? Vacuum leaks? tune up done? We should start with a compression test, this guide can help:
Please go over this guide and report back.
Nov 12, 2022 at 2:19 AM
GERRY SATTERWHITE
Okay, I'll do that as, my muffler man, said drivers side had a miss, I've change wires and plugs plus new distributor. still with all that's been done, I suspect the PCM, or fuel injection computer Ox sensor idle air control valve stuck open. I have a Ford code reader and book.
Nov 13, 2022 at 2:47 AM
  • 55,710 POSTS
To see which cylinder is misfiring you can use a temperature gun on the exhaust manifolds to see which cylinder is running cold, then check the fuel injector pulse.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
and then see if the cylinder is getting spark.
https://youtu.be/baq_aEWNQ0Y
and
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Please go over these guides and report back.
Nov 14, 2022 at 2:03 AM
