Engine sputters and acts like it wants to shut off when decelerating
13,200 MILES • 2.9L • 4 CYL • 2WD • AUTOMATIC
KEITH WANN
When slowing down and braking at a stop sign the engine sputters and wants to shut off, but doesn't actually shut off. Other wise it runs fine. Thanks
Nov 8, 2019 at 7:03 AM
Good evening,
This could be an EGR valve stuck open causing a massive vacuum leak.
https://www.2carpros.com/articles/engine-surges
Is the check engine light on?
Can you verify the engine size?
Nov 8, 2019 at 8:09 AM
