HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Symptoms
Stall While Driving
SPONSORED LINKS
Engine loaps in stop and appears the truck wants to Move forward.
BIRDHUNTER23
MEMBER
2004 FORD F-150
4.8L
V8
2WD
AUTOMATIC
210,000 MILES
When the truck is stopped at a red light in drive it will start loaping and it appears it wants to move forward.
Friday, January 30th, 2015 AT 5:22 PM
HMAC300
MECHANIC
Try cleaning throttle plate on both sides
SPONSORED LINKS
Saturday, January 31st, 2015 AT 6:38 AM
KEN L
MASTER CERTIFIED MECHANIC
Yes, a dirty throttle body will cause this issue, here is a video to help you fix the problem.
https://youtu.be/6fWYjfU9UV8?si=wU9AoLz3hOHq_8ZO
Please go over this guide and get back to us.
Monday, August 12th, 2024 AT 5:37 PM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
Will Stall As Soon As You Let Off?
When Truck Idle Is Low And You Give It A Little Gas, Engine Will Stall As Soon As You Let Off.
Asked by
blueman1
1 ANSWER
2004
FORD F-150
VIDEO
How to Read Codes
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
2001 Ford F150 Shuts Off While Driving In Hot Humid...
My 2001 F-150 Has Started Stalling, While Driving But Only On Days When It's 90 Degrees Plus. It's Happened With And Without The A/c Being...
Asked by
lusluckylad
2001
FORD F-150
Engine Will Start But Not Idle
I Have A 97 Ford F150 4x4 4.6l 5 Speed 98000miles. It Starts But Will Only Stay On If My Foot Is On The Gas. My Check Engine Light Is On And...
Asked by
smitty1224
1 ANSWER
FORD F-150
1986 Ford F-150 Truck Shutting Down Around 40mph
I Have An 86 F150 With An 87 Engine In It. It Runs Well In Park Or Neutral. I Can Rev The Engine With No Issues. Take It On The Road And...
Asked by
phtd1990
1 IMAGE
1986
FORD F-150
1986 Ford F150 Engine Stalls And Hesitate
Engine Performance Problem 1986 Ford F150 V8 Two Wheel Drive Automatic When It Gets Hot It Gives A Me Problems Like Its Flooding It...
Asked by
chedder91
1986
FORD F-150
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear
Topdon OBD2 Scanner Review - This thing rocks
Check Engine Light
Online car repair manuals
