Engine light on blinks and just stays on
130,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
TRACY TRINIDAD
When driving the car will miss then lose power light will start to blink pull over and then it will stay on as i stop it will run rough. Turn car on after awhile and lite stays on but not blinking drive home and start after a couple of hours. Lite is off and running fine no rough idle. Has been happening over and over. Replaced camshaft sensor plugs and 1 coil pak.
Aug 23, 2019 at 2:09 AM
Good afternoon,
I would start with replacing the plugs. It sounds like an engine misfire. I always start with the basics.
Aug 23, 2019 at 5:24 AM
TRACY TRINIDAD
Thank you for the response. i forgot to say i did replace the plugs also. Codes were p0300 and p0301 multiple misfire and cylinder one. so that is why i replaced the one coil pak additional code was crankshaft sensor. replaced it also the one code i am not sure needs addressing is p0335 airbag. i am almost sure this will not cause the symptoms that i have. Almost acts like it jumps time but i would think that if that was the case it would not reset to normal after sitting. today it started happening at start up and hard to start when in this condition. But when i got home and started it again light was out and running fine. could this be a sign of a electrical issue?
Aug 23, 2019 at 7:10 AM
Okay I would do a compression test on the cylinders to be sure the engine is internally good.
https://www.2carpros.com/articles/chirping-noise
Aug 23, 2019 at 7:13 AM
TRACY TRINIDAD
A compression issue would be continues correct? so how would that be my intermediate problem? The issue is not continues i can drive 50 mike before it happens then arise after i stop and attemt to restart
Aug 23, 2019 at 7:36 AM
Yes it could. That is why you need to check it. You have to start somewhere and that is where we start.
Beyond that, it could be plugs, coil, injector or a vacuum leak but the basics need to be verified first.
Aug 24, 2019 at 9:27 PM
TRACY TRINIDAD
Thank you. i will get it done. hoping it is okay.
Aug 25, 2019 at 12:02 AM
You are welcome.
Keep me updated.
Aug 25, 2019 at 12:06 AM
