Engine light stays on, code Po308
180,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
SHIRLEYS
  • 25 POSTS
I had a code po308 I changed the coil pack and put a new spark plug in the gap was way off on the old one. I tried to reset the engine light with OBD reader but when you drive it, it comes back on I put OBD reader back on it shows no codes.
Dec 14, 2021 at 5:36 AM
Good evening,
The first thing I would do is a compression test on cylinder 8 to be sure there is compression for the cylinder to work.
These engines have a habit of burning exhaust valves. You can rent a tester at a parts store for this test.
You need 140-160 pounds.
Dec 14, 2021 at 6:53 AM
