Engine light stays on
77,000 MILES • 1.2L • MANUAL
YUM123
Hi folks,
So my engine light has been on for quite some time. At first it would come on and then turn off by itself, sometimes mid drive. But it's been on for quite some time now.
I had an MOT which failed because of this and the ABS light. ABS was fixed and engine light turned off too. I drove 20 miles to work and as I pulled into the carpark, the light came on again.
I've just used my lunch hour to take it for a drive and the light is on again from the time I start the engine. It's cost me a fortune this far and I'm at my wit's end.
Please, someone help? I'd be really grateful.
Mar 3, 2020 at 10:52 PM
Good morning,
Can you give me the code that keeps setting? I need that code to further narrow the area of failure so I can help you get to a resolution.
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
Mar 3, 2020 at 11:16 PM
YUM123
I don't have a code. I may need to ask the garage for this. I'll be back when I have an answer from them.
Mar 4, 2020 at 8:32 PM
Sounds good. We will be here to help.
Mar 4, 2020 at 8:34 PM
