2000 Vauxhall Corsa Engine light on and battery dead
DINO_FULTONA
  • 2000 VAUXHALL CORSA
Electrical problem
2000 Vauxhall Corsa Two Wheel Drive Manual 54000 miles
Hi Car Repair I was hoping you could help me, my vreg 1.0 corsa has been running funny for a while now, loosing power mid acceleration and hunting when pulling away. I had the spark plugs replaced a couple of months ago with no change. The engine light has now started to stay on and the battery has completely died with no response after turning the ignition. I've taken the battery out the car to try and charge it up, is this ok? What could be causing the problem? Was going to get it put on the diagnostic machine when the battery died so I need to try sort that first. The cost of repair is looming in my mind, but I really want it running again as its a good car usually. Hope you can help me, Thanks.
Saturday, April 4th, 2009 AT 12:06 PM
DAVE H
  • 13,384 POSTS
Recharge the battery or replace with new .. install battery on car and reset the immoboliser .. by locking and unlocking the doors ... have the vehicle plugged into a diagnostic computer to find out why the MIL is coming on and repost with the full fault codes for a better diagnosis and repair information !
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_435.png
Sunday, April 5th, 2009 AT 7:23 AM
DINO_FULTONA
I've put the battery back in and its supplying all the power and has managed to start the car eventually however the alternator light is staying on constantly and the MIL light, could there also be a problem with the alternator? Noticed a strong burning smell while engine was running. I'm phoning to book it in to the garage tomorrow.
Monday, April 6th, 2009 AT 3:02 PM
DAVE H
  • 13,384 POSTS
The alternator will need replacing ... this was probably the fault all along .. have the alternator replaced and have the vehcle plugged into a diagnostic computer to verify why the MIL is on .. I think this will just be from a power loss to a sensor !!
let me know
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_449.png
Monday, April 6th, 2009 AT 7:27 PM
DINO_FULTONA
Garage said its needs a new alternator like you said and a EGR valve? I've been quoted  460 for the parts and labour, thats also including being put on the diagnostic machine.
Wednesday, April 8th, 2009 AT 9:58 AM
DAVE H
  • 13,384 POSTS
The EGR valve fault may just be showing because of a low voltage supply caused by the alternator malfunction ... I would have them repair the alternator and clear the codes from the cars computer and then see if the EGR fault code returns .. ?
hope this helps .. let me know
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_473.png
Wednesday, April 8th, 2009 AT 10:12 AM
