Code P0073, engine light on the time?
225,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
HOUSESTEPHEN
  • 6 POSTS
engine light on the time code P0073? I replaced sensor.
Mar 29, 2025 at 12:58 AM
  • 55,845 POSTS
So if you replaced the ATS sensor then I would check the wiring. Here is a guide to help and the wires you should be checking in the images below.
P0073 – Ambient Air Temperature Sensor Circuit High
You must have a broken wire or bad connection, check out the images (below). Let us know what you find.
Mar 29, 2025 at 9:46 AM
