engine light on need to know codes
98,500 MILES • V8 • FWD • AUTOMATIC
DAVE OGE
PCM P0481, RSS C0579, RSS C0584.
Aug 22, 2016 at 3:33 AM
HMAC300
  • 48,601 POSTS
the first one is cooling fan circuit, so check relays under hood fuse box and then it has to be checked for broken wiring /or a short. the second two are for the electronic suspension which a mechanic will need to hook his scanner up to do some commands to test to see what is wrong with that particular circuit.
Aug 22, 2016 at 5:07 AM
