Engine light on code indicated an issue with the tc clutch, a P1740
200,000 MILES • 4WD • AUTOMATIC
LESLYE
What is the cost to fix this issue. Had transmission done at 150,000 miles in 2011. Car well maintained if repaired what is the likely hood of it lasting at least 3-5 years.
Dec 29, 2017 at 4:08 AM
  • 55,743 POSTS
It could be just the TC solenoid that is out which would cost about $70.00 for the part and you can install it yourself.
Here are diagrams below to help you
Cheers, Ken
Dec 31, 2017 at 6:18 AM
