engine light on
JLOBAINA
  • 18 POSTS
1998 honda accord engine light comesw on when I put obd scanner comes up with p1739 * p1399 I would like explanation on these codes? & if anything what can I do to fix the problem? is the tranxhasel inside the trasmition?
May 26, 2013 at 11:02 PM
Honda does not supply a diagnostic flow chart for this code. P1399 is a random misfire code and Honda/Acura has reported for various models that this could be caused by clogged EGR ports. In addition there is the possibility that the valve clearance specification may be out of range.
1739
DTC P1739: Problem in 3rd Clutch Pressure Switch Circuit
NOTE: Record all freeze data before you troubleshoot.
Turn the ignition switch ON (II).
Measure the voltage between the B24 and B20 or B22 terminals. Is there battery voltage?
YES - Go to step 7.
NO - Go to step 3.
Turn the ignition switch OFF.
Disconnect PCM connector B (25P).
Disconnect the 3rd clutch pressure switch connector.
Check for continuity between the B24 terminal and body ground. Is there continuity?
YES - Repair short to ground in the wire between the B24 terminal and the 3rd clutch pressure switch.
NO - Check for loose terminal fit in the PCM connectors. If necessary, substitute a known-good PCM and recheck.
Raise the front of the vehicle, and make sure it is securely supported.
Set the parking brake, and block rear wheels securely.
Start the engine, then shift to D3 position and drive in 3rd gear for more than five seconds.
Measure the voltage between the B24 and B20 or B22 terminals. Is there about 0 V ?
YES - Check for loose terminal fit in the PCM connectors. If necessary, substitute a known-good PCM and recheck.
NO - Go to step 11.
Measure the voltage between the 3rd clutch pressure switch connector terminal and body ground. Is there battery voltage?
YES - Go to step 15.
NO - Repair open in the wire between the 3rd clutch pressure switch and the PCM.
Measure the resistance between the 3rd clutch pressure switch connector terminal and body ground. Is the resistance 10 M ohms or more ?
NO - Replace the 3rd clutch pressure switch.
May 26, 2013 at 11:26 PM
JLOBAINA
  • 18 POSTS
thanks I decided to replace transmition
May 27, 2013 at 4:51 AM
