Engine light on
112,000 MILES • 1.6L • MANUAL
MICHELLE DOWZELL
My engine light has came on in car. it came up on my dash display antipollution fault, i only had my car serviced two weeks ago.
Jan 19, 2017 at 4:11 PM
WRENCHTECH
  • 20,760 POSTS
The "check engine" light is an indicator for a system that monitors many electronic functions in the system, also called the "malfunction indicator lamp" (MIL). It can come on for any of hundreds of different causes from any of the systems that the computer monitors. Some are very important and can lead to further component or engine damage and some are emissions related not as serious but still a problem and need to be repaired.
Your first step is to have the computer scanned to retrieve the trouble codes that were set when the check engine light came on. Those codes will give you specific information about what the computer saw and will get you pointed in the right direction to find your problem.
Jan 19, 2017 at 8:18 PM
