Engine light/misfire?
196,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
KEVIN HOOVER
Firstly, when I jump the 2 pins in the diagnostic connector, the check engine light just flashes without stopping. It does not spit out any codes. Is this normal as nothing is wrong? Or should a specific code tell me everything is okay like on Nissans?
Nov 3, 2023 at 6:50 AM
  • 110,248 POSTS
When you jump the DLC, the check engine light should flash code numbers. Take a look through this link and let me know if this is what you are doing:
https://www.2carpros.com/articles/lexus-trouble-codes-obd1-1990-1995-code-retrieval-procedure
Nov 3, 2023 at 2:16 PM
