Engine light is intermittent code read retrieval P0122 ,P0123 , P0121
What are these codes translate please
Feb 22, 2016 at 11:37 PM
JDL
✓Experienced Mechanic
The codes relate to throttle position sensor. I usually want to check sensor wiring circuits first. ref voltage--ground and signal wires. You can use digital multimeter, backprobe signal wire, key on, no need to start it, check that the voltage readings on the meter move up and down smoothly, no glitches or cutouts on the reading. If all that checks out, I don't see the problem, at the moment.
Feb 23, 2016 at 5:27 AM
JDL
Move the throttle with your hand, open and close, notice the readings.
Feb 23, 2016 at 5:28 AM
RICHARD EVANS
MEMBER
Thank you so much for your time and expert knowledge ..!!
Where's the location for the throttle positioning sensor ?
Feb 24, 2016 at 12:39 AM
JDL
The tps is on the throttle body. Number 5 in the picture. The add image link didn't seem to work. I'll try something else.
Feb 24, 2016 at 1:10 AM
RICHARD EVANS
MEMBER
Thanks !! Anything you can do is greatly appreciated thanks again !!! An Image would be terrific
Feb 24, 2016 at 1:37 AM
JDL
I can't seem to post an image, at the moment? If I figure it out, I'll post back.
Feb 24, 2016 at 1:51 AM
JDL
It's number 5 in the picture.
Image (Click to enlarge)
Feb 24, 2016 at 2:28 AM
RICHARD EVANS
MEMBER
Thanks so much for the image hey greatly helps I will keep you posted on the outcome with greatest sincerely Richard
