Engine Light Flashing After Purge Valve Replacement
101,000 MILES • 6 CYL • AWD • AUTOMATIC
CHRIS HANNACK
My check engine light has been on for a while, and I was told it was because of a faulty purge valve, and that it was not really serious. I finally got around to replacing it (did it myself, but seemed fairly straight forward). I took it out for a drive, and after about ten minutes, I could feel the car pulse slightly, almost like I was letting off the gas, and the check engine light started blinking, but only for a few seconds. Any idea what could have caused this?
Aug 10, 2016 at 12:29 PM
HMAC300
  • 48,601 POSTS
you have to have the code erased after changing a part and that may be the problem. get it erased then start over.
Aug 10, 2016 at 11:08 PM
CHRIS HANNACK
I took it in, and it came up with P0014 and P0024, which show as both cam shaft issues. Not sure why this would happen after replacing a purge valve.
Aug 11, 2016 at 6:19 AM
HMAC300
  • 48,601 POSTS
could be it jumped time or chain is stretched.
Aug 11, 2016 at 8:58 AM
