Engine light turns on and off while driving
280 MILES • 1.6L • 2WD • AUTOMATIC
WISEMAN28
  • 5 POSTS
Suddenly it shows engine light on and off but losing power and rev count does not go above two. I have to keep on rev it to avoid to switch off. Please help!
May 18, 2018 at 2:59 PM
  • 110,251 POSTS
Hi and thanks for using 2CarPros.com. The first thing you need to do is have the computer scanned. If the check engine light is coming on, there will be trouble codes stored which will indicate where the problem is coming from.
Here is a video for scanning a computer:
https://youtu.be/b2IJGfImVvw
Here are the top causes for a check engine light:
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
If the light is on, is it safe to drive. Take a look at this link:
https://www.2carpros.com/articles/check-engine-light-is-it-safe-to-drive
If you scan the vehicle yourself, you will need to find the data link connector, (DLC). It is under the dash on the driver's side. I have attached two pictures for you. Note: Many of the parts stores will scan the computer for you for free.
Once you find the trouble codes, get back to me and let me know what you found. That way, I can help solve the problem.
Take care and I hope this helps.
May 19, 2018 at 1:47 PM
