engine light came on after driving 30 minutes after repair.
180,000 MILES • 4 CYL • MANUAL
A2NDOPINION
Power steering pressure hose was replaced today. Engine light came on after 30 minutes (total) driving. RPM started fluctuating over 1/engine revving.
Thermostat was replaced 5 mos. ago.
Aug 26, 2016 at 3:03 PM
SATURNTECH9
  • 30,869 POSTS
First thing you need to do is have it scanned for codes and let me know the exact code numbers not code descriptions?
Aug 26, 2016 at 3:21 PM
A2NDOPINION
All I know so far is egr valve, do not have # displayed on scanner.
Aug 26, 2016 at 3:27 PM
SATURNTECH9
  • 30,869 POSTS
Knowing the exact code numbers not code descriptions would really help otherwise we would just be guessing why the check engine light is on.
Aug 27, 2016 at 1:23 AM
A2NDOPINION
A vacuum line was not hooked up. Thank you for your input. Will make a note to ask for code # next time.
Aug 27, 2016 at 4:42 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome glad you found it.
Aug 27, 2016 at 12:54 PM
