Engine light on, code P0304
160,000 MILES • 5.3L • V8 • AUTOMATIC
BASSCHELSEA061
Engine light came on, sometimes it just blinks and sometimes it will just stay lit. Gave trouble code P0304 misfiring, and service stabilitrek and traction control light on.
Dec 31, 2017 at 1:07 AM
Good morning.
The 304 is a misfire code for cylinder number four. In most cases, it is a spark plug or coil. How long has it been since you had a tune up?
Dec 31, 2017 at 1:54 AM
BASSCHELSEA061
Not sure, but I did a compression check and I only have 35 psi on that cylinder and 120 on the other ones.
Dec 31, 2017 at 4:34 AM
Okay, good find. You have an issue in that cylinder. It is either burned valve or damaged piston. It will require removing the head for inspection.
Dec 31, 2017 at 4:40 AM
