Engine light
110,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
FREYA3213
Occasionally when I change from third to fourth gear my engine light will pop up for a second then disappears. It's still runs normally and doesn't happen often what could it be?
Aug 21, 2019 at 1:41 PM
  • 55,710 POSTS
This sounds like the MAF sensor is not working correctly. To be sure lets run the codes to confirm. Here is a guide to help with the sensor location in the diagrams below:
Aug 23, 2019 at 6:51 AM
