Engine light on, code p0660
265,000 MILES • 6 CYL • AUTOMATIC
SHELIALEE38
I put my car on the machine because engine light came on. It came back with code p0660 manifold tuning valve. I replaced the whole unit and the light still on with the same code p0660. What can I do next to fix the problem?
Nov 11, 2018 at 9:54 PM
Good morning.
The issue needs to be diagnosed before replacing anything. that was an expensive guess. Codes rarely identify bad parts, they show systems that have a failure.
Anyway, I listed possibilities below for the code as well as a description.
The first thing you should do is verify power and ground to the unit. Wiring diagram attached.
P0660
Descriptor
Manifold Tuning Valve (Mtv) Control Circuit
Probable Causes
(Z816) Ground Circuit Open or High Resistance
Intermittent DTC
Manifold Tuning Valve (MTV) Assembly
Manifold Tuning Valve (MTV) Control Circuit Open or High Resistance
Manifold Tuning Valve (MTV) Control Circuit Shorted to Ground
Manifold Tuning Valve (MTV) Control Circuit Shorted to Voltage
Powertrain Control Module (PCM)
flow chart that requires a scan tool and a voltmeter.
When Monitored:
With the engine run time above a calibrated value, battery voltage greater than 10.4 volts, ECT within a specific range, and the Manifold Tune Valve Assembly control active.
- Set Condition:
This PCM compares the circuit feedback to a calibrated closed range when the circuit is de-energized or to a calibrated open range when the circuit is energized. If the value is determined to be out of the calibrated range in either the de-energized or energized state for more than a calibrated amount of time, this DTC will set.
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding.
Diagnostic Test
1. DTC IS ACTIVE
Turn the ignition on.
With the scan tool, Clear DTCs in the Powertrain Control Module (PCM).
With the scan tool, actuate the MTV Solenoid Control State.
With the scan tool, select View DTCs.
Is the status Active for this DTC?
- Go to 2
- Refer to the *CHECKING FOR AN INTERMITTENT DTC Diagnostic Procedure. See: Computers and Control Systems > Component Tests and General Diagnostics > Checking for an Intermittent DTC
2. (K136) MTV CONTROL CIRCUIT SHORTED TO VOLTAGE
Turn the ignition off.
Disconnect the Manifold Tune Valve Assembly connector.
Disconnect the Powertrain Control Module (PCM) connector.
Measure the voltage of the (K136) MTV Control circuit in the Manifold Tune Valve Assembly harness connector.
Is there any voltage present?
- Repair the (K136) MTV Control circuit for a short to voltage.
- Perform the PCM Verification Test. See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > PCM Verification Test
- Go to 3
3. (K136) MTV CONTROL CIRCUIT SHORTED TO GROUND
Measure the resistance between ground and the (K136) MTV Control circuit in the Manifold Tune Valve Assembly harness connector.
Is the resistance above 100 ohms?
- Go to 4
- Repair the (K136) MTV Control circuit for a short to ground.
4. (K136) MTV CONTROL CIRCUIT OPEN OR HIGH RESISTANCE
CAUTION: Do not probe the PCM harness connectors. Probing the PCM harness connectors will damage the PCM terminals, resulting in poor terminal to pin connection. Install Miller Special Tool #8815 to perform diagnosis.
Measure the resistance of the (K136) MTV Control circuit between the Manifold Tune Valve Assembly harness connector and the appropriate terminal of special tool #8815.
Is the resistance below 5.0 ohms?
- Go to 5
- Repair the (K136) MTV Control circuit for an open circuit or high resistance.
5. (Z816) GROUND CIRCUIT OPEN OR HIGH RESISTANCE
Using a 12 volt test light connected to 12 volts, check the (Z816) Ground circuit in the Manifold Tune Valve Assembly harness connector.
NOTE: The test light should be illuminated and bright. Compare the brightness to that of a direct connection to the battery.
Is the test light illuminated and bright?
- Go to 6
- Repair the (Z816) Ground circuit for an open circuit or high resistance.
6. MANIFOLD TUNE VALVE ASSEMBLY
Connect the Powertrain Control Module (PCM) connector.
Using a 12 volt test light connected to ground, check the (K136) MTV Control circuit in the Manifold Tune Valve Assembly harness connector.
NOTE: If the DTC is active, the actuation test may not be allowed by the PCM. If may be necessary to clear the DTCs before starting the actuation.
NOTE: The voltage supplied to the solenoid circuit during the actuation may be less than battery voltage. The test light should be illuminated, but may not be as bright as a direct connection to the battery.
Is the test light illuminated during the actuation?
- Replace the Manifold Tune Valve Assembly.
- Go to 7
7. POWERTRAIN CONTROL MODULE (PCM)
Using the wiring diagram/schematic as a guide, inspect the wiring and connectors between the Manifold Tune Valve Assembly and the Powertrain Control Module (PCM).
Look for any chafed, pierced, pinched, or partially broken wires.
Look for broken, bent, pushed out or corroded terminals.
Refer to any Technical Service Bulletins that may apply.
Were any problems found?
- Repair as necessary.
- Replace and program the Powertrain Control Module (PCM).
Nov 11, 2018 at 10:22 PM
