Hello, I am Danny.
Actually yes, that is the first step. Code P0455 is Evaporative Emission Control System Leak Detected (Gross Leak). I would first inspect the rubber o-ring on the gas cap to see if cracked/split/torn. Make sure after tightening cap go about three clicks more. If going to replace cap, after tightening go three clicks more. Clear codes and see if Check Engine Light comes back on. If so, we will go from there. I have attached a tutorial for you to view. Hope this helps and feel free to ask any other questions.Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/evap-system-code-repair
Friday, September 7th, 2018 AT 10:22 PM
