Scanner is not working?
147,000 MILES • 5.4L • 6 CYL • 2WD • AUTOMATIC
MIKE RIVERA
Put scanner on it and it comes up briefly and is not working?
Jan 5, 2022 at 7:26 AM
  • 110,248 POSTS
Do me a favor. I need you to check if there is power at pin 16 in the data link connector. Additionally, confirm pins 4 and 5 provide continuity to ground.
I attached a pic below showing which to check. Here is a link you may find helpful:
Let me know what you find. Also, if you could video what the scanner does and upload it for me to see, it may help.
See pic below.
Jan 9, 2022 at 10:47 AM
