Check Engine light
140,127 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
JGARCI62
Codes po171 - p1148 - p1272 - p1031. What is the problem? Thank you
May 25, 2016 at 12:39 PM
  • 110,248 POSTS
These codes indicate there is a lean fuel mixture. Check first for vacuum leaks. If none are present, most likely the air / fuel sensor is bad or there is a wiring issue to this component. Also, there was a technical service bulletin (TSB) on this vehicle which relates to this problem. I do not have access to Nissan's archives, but if you contact a dealer, they should be able to help.
May 25, 2016 at 1:40 PM
JGARCI62
Hi, I installed a new one, but without wire connector and I welded the old one oxygen sensor. The heat damaged the sensor or no?
May 26, 2016 at 12:37 AM
DOCHAGERTY
  • 9,606 POSTS
Possibly yes
May 26, 2016 at 9:26 AM
JGARCI62
So the heat of welding wires damage the inside of sensor?
May 26, 2016 at 9:31 AM
  • 31,937 POSTS
use a scanner with a live data feed and you can watch the O2 sensor change voltage, if this is evident it is working ok.
May 27, 2016 at 10:25 AM
