Engine light turns on while driving over 50 MPH
204,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
WADE#1
After 50 MPH engine light comes on. pull fuse and engine light off until driven over 50 MPH. Transmission shifts good through all gears and no problems.
Jan 12, 2022 at 1:19 AM
SQM
  • 6,383 POSTS
So, have you scanned the vehicle to see what code(s) you are getting?
If not, that will be a good first step. As that can help with the diagnostics. This issue could be due to any number of sensors or components.
And from your question it sounds like the transmission shifts normal up to 50 MPH then it has issues?
What else are you experiencing?
Please let me know.
Jan 12, 2022 at 2:12 AM
WADE#1
no issues through any gear shifts great will get code and send it to you.
Jan 12, 2022 at 10:37 PM
SQM
  • 6,383 POSTS
Okay, I will look out for the codes.
Jan 13, 2022 at 1:36 AM
