Engine light turns on but when i turn off the car and turn it on again the light turns off?
280,000 MILES • 1.8L • 4 CYL • TURBO • 2WD • MANUAL
KLEDIS
I have the car listed above 1.8 TDCI. The check engine turns on but when i turn off the car and turn it on again the light turns off. i change the oil pump.
Jan 26, 2024 at 2:00 AM
  • 55,673 POSTS
Yep, this is normal when you have a trouble code stored, we need to connect a scanner tool to pull up the codes so we can go in the right direction.
Please go over this guide to get started:
This guide can help as well:
https://www.2carpros.com/articles/what-is-a-check-engine-light
Please go over these guides and get back to us.
Jan 26, 2024 at 4:11 AM
