Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Equinox
Engine
Symptoms
Low Power
engine light and loss of power
2006 CHEVROLET EQUINOX
16,400 MILES • 1.3L • V6 • 2WD • AUTOMATIC
SANDRA MARRERO
MEMBER
1 POST
engine loses power and does not accelerate.
Oct 8, 2020 at 4:49 PM
Experienced Mechanic
Good morning,
Can you give me the code that s set? A parts store will read the code for free or you could get a cheap code reader for this. Once I know the codes, I can narrow the area of failure.
https://www.2carpros.com/articles/engine-has-low-power-output
As far as the low power, I would start with checking the fuel pressure to be sure sufficient fuel is being delivered to the fuel rail.
The other thing is the catalytic converters. If they are clogged, it will do this.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Oct 8, 2020 at 8:40 PM
Add image or video
Ask a new question
Engine won't start
Engine overheating
