Engine knocking on start up idle, before and after warm up
209,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
K3N3T1K_K
  • 8 POSTS
The clean idle sound is not happening anymore. It’s been doing this since I had the timing off and bad distributor. I had a sputtering issue and I replaced the the spark plugs and wires (NGK). Before replacing the distributor. Once I replaced the the distributor the sputtering went away. Since then I’ve adjusted the time for less sluggish acceleration. So that has improved, and recently brought the idle down from 1,000 rpm to 900 rpm. The idle screw is maxed out. So I’m also trying to figure out why I can’t get the idle between 700 or 750 rpm?
Nov 11, 2019 at 10:23 PM
SCGRANTURISMO
  • 4,897 POSTS
In a manual transmission vehicle you want to have the idle a little higher than you would in an automatic transmission vehicle to help with the clutch engagement when starting out in first gear. 900 - 1000 R.P.M.'s is right about where you want your vehicle to idle. I hope this helps.
Thanks,
Alex
2CarPros
Nov 12, 2019 at 9:15 AM
