Engine knocking on petrol
40,000 MILES • 1.0L • 3 CYL • MANUAL
HARSHNEGI97
i have zen estilo (2007) done 62000. i have cng fitted from outside. the car works fine on cng but give jerks on petrol. local mechanic says it is a problem with advancer. Another one says it is a problem with throttle body and injectors.Help!
Feb 19, 2019 at 11:54 AM
  • 110,246 POSTS
First, this vehicle isn't available in the US, so my technical information is very limited. However, when you get valve noise or poor performance, often times it is related to either the fuel octane is too low or the engine knock sensor is bad. The knock sensor is responsible for adjusting engine timing to maintain the best performance. If it fails, timing may be compromised.
Take a look through this link and see if it helps.
https://www.2carpros.com/articles/how-a-knock-sensor-works
Feb 19, 2019 at 12:10 PM
